I lifted this directly from the Curiouslabs site Poser 4 FAQ. My computer freezes before it finishes rendering my animation. What do I do? This could be a video card driver issue. Make sure you have the latest drivers for your specific video card. You may also try reducing Hardware acceleration. Right-click the desktop > choose properties. The Display Properties control panel will open. Click Settings > Advanced > choose either Performance or the Troubleshoot tab. Adjust the Hardware acceleration slider to lower settings and test your Programs.
"a big number frames animation ( 200-300 frames) with high detailed characters and a environment full of objects" That's probably your issue. 1 GB of RAM ain't a hell of a lot if you're trying to do something really ambitious. A lot of detailed models and an environment full of objects is taxing enough on single frame renders.
Yes, but this big V3 will add up over time very fast and if the memory is not cleaned up there is an end in view. With a normal V3 I could render on a machine with 1 gig memory from 100-300 frames then the end was reached. The same problem occurred when I rendered the same V3 in the same frame from Python and it had nothing to do with the movie
The "render to image files" solution is the best one I know of if you don't have Poser 5 SR4.1 (which as you've got Poser 4, you won't have).
If you render out to a sequence of image files then you can use the "Animation Palette" to select the range to preview and render. If you crash at frame 150 then set this to go from 151 to end when you reload, and rendering will resume at frame 151 :)
As a matter of interest, if you render to image files this way then you can fairly easily adjust small parts of your animation and only re-render the frames which have changed :)
Cheers,
Cliff
When i try to render a big number frames animation ( 200-300 frames) with high detailed characters and a environment full of objects in Poser 4 i get a memory error message in about frame 100. I think a have a enough powerfull machine ( Pentium 4 2800, Windows XP, 1G RAM memory, Ati Radeon 9600 pro). Why do this thing happen?, Do i need a more powerfull computer?
