Sun, Jan 26, 12:55 AM CST
Subject: Anyone who ever good job with Pose Genie , plz help
jibrielson ( ) posted Tue, 20 April 2004 at 2:46 AM ยท edited Fri, 24 January 2025 at 6:34 PM
Hi... everyone Im still confuse with Posegenie ( provided by Bushi ) , after read threads in here , and PDF document which included with script , im still couldn`t make the seeker to close enough with target based on Don examples ( PDF document )these my question : 1.Does base , target , or seeker position impact the result ? 2.Should I process one by one actor ( collar , shoulder , forearm & hand )with script ? 3.What exactly this script do? change the limit ? 4.Does this script only change the limit and i still should manually move an actor by dial? If anyone ever done with script , plz let me know , more appreciated if supply with base , target or seeker coordinate , so i can study what stupideous thing i did thanks for help Note : both pics after running posegenie 120 times...!! Poser 5 SP4 PoseGenie V2 by bushi Jibriel
c1rcle ( ) posted Tue, 20 April 2004 at 3:58 AM
There's a V2 of PoserGenie? I really have to learn to stay awake 24hrs a day so I don't miss things like this :(
KarenJ ( ) posted Tue, 20 April 2004 at 3:23 PM
First of all, I find it easiest to use the orthagonal cameras (front, left, top etc) when positioning the target and seeker. This can solve a lot of problems. Also remember to turn IK off. Now, what pose are you trying to make? It looks like you want Don's hand by his knee. Position the markers like this: The base is the WHITE ball. Move it up to about the centre of Don's chest. The seeker is the RED ball. Put it in Don's hand. The target is the YELLOW ball. Put this where you want Don's hand to end up, in this case, mid-thigh.
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan Shire
KarenJ ( ) posted Tue, 20 April 2004 at 3:38 PM
Parent the seeker to the right hand. Now select in the PoseGenie window, the body parts which need to move. I'm going to start with right collar, shoulder, left forearm and left hand. If you don't get close enough with that, you can try either adding some side-side to the chest, or changing the limits slightly - however bear in mind that limits are there for a reason, and the mesh may look very odd if you go beyond those limits. The above pic is the result after 20 generations. Don can't get his hand any further down his thigh without bending slightly (or by me scaling his arms longer.) Does this help?
"you are terrifying
jibrielson ( ) posted Wed, 21 April 2004 at 3:22 AM
thankz , i`ll try
