Tue, Jan 28, 5:15 PM CST
Forum Moderators: Staff
Subject: Judy Eye Transformations ... Question about centers
DCArt ( ) posted Wed, 14 April 2004 at 11:07 AM ยท edited Mon, 27 January 2025 at 6:39 AM
Hi folks! I'm putting the finishing results on a Poser 5 face morph set, but I have a nagging problem that I might need a solution for. I created some morphs in ZBrush, and some of them reshape the face quite extensively. To move the eyes, I created morphs that would adjust each eye position along the X, Y and Z axes, and also make the eye larger or smaller. The problem that I am seeing, however, is that if I use these fine adjustments and then try to pose the eyes afterwards (either through "Point At" or manually), the eyes seem to rotate around the original center point and they get all kiltered. So ... being that I don't notice this in the Millenium figures, I don't know if it's the fault of the morphs or not. Is there a way around this? Is there some sort of kludge that can be put in the CR2 to move the center point of each eye with the positions? Thanks in advance.
OddDitty ( ) posted Fri, 16 April 2004 at 4:31 AM
I'm fairly certain the morphs have altered the Joint params of the default eyes, or it could be that when they are applied, the new geom throws the JP's off kileter. It's done that to me before, and Garreee had that issue pretty heavily witht he morph set he created for the DAZ pixie. I believe he worked most of it out by adapting the JP via Pose files.
DCArt ( ) posted Fri, 16 April 2004 at 7:15 AM
OK, so if I'm taking this correctly, there isn't really a way to modify the CR2 so that you can adjust the center point of the eye while you adjust the position of the eye? That would be the ideal solution.
OddDitty ( ) posted Fri, 16 April 2004 at 10:10 AM
Not that I'm aware of -- and I've tried to do so several times in essence, though not specifically with the eye. You may be able to adjust the jp of the morph, however, now that I think about it, as there is JP information saved in with the deltas. But I really have no clue how you'd go about it. That would require the serious eggheads. I'm only a semi-serious egghead.
DCArt ( ) posted Fri, 16 April 2004 at 10:12 AM
LOL Me too ... thanks for the input! I appreciate it.
lesbentley ( ) posted Sat, 24 April 2004 at 6:56 PM
Deecey, you say "the eyes seem to rotate around the original center point". Yes they will rotate around the original center point, a morph target only moves vertices, it can have no effect on the center point or any joint paramiters.
I am afraid that OddDitty is mistaken in post #2 when he/she says "I'm fairly certain the morphs have altered the Joint params..." This just does not happen. The statement in post #4 "as there is JP information saved in with the deltas." Is also mistaken, there is no JP information in the deltas, deltas only relate to vertices, not JPs.
The best way round this problem is usually not to morph the eyes at all, instead translate and/or scale them. When you translate the eyes their origens move with them.
If for some reason you really do have to change the rotational centers for the eyes there are a number of ways to impliment the change.
The rotational center for an actor (body part) is called its "origen". There will be a line in the cr2 for each actor that specifies its origen, the "origen" line will probably be near the very bottom of each actor block in the cr2. It will look somthing like this:
 endPoint -0.013 0.662 0.037<br></br> origin -0.013 0.662 0.03<br></br>    orientation 0 0 0
You can change the position of the origen by using the joint editor to change the "center". You can edit the origen lines in the cr2 using a text editor. Or you can use a pose file to inject a new origen, this latter way is obviously prefferable if you are applying the morph as delta injection, as the one pose file can do both jobs.
DCArt ( ) posted Sun, 25 April 2004 at 9:55 PM
instead translate and/or scale them The problem that I fine with using the Trans dials is that there is not a fine enough resolution to get the minute adjustments that one might need. A change of position of .001 either way on an eye is often much more than is needed. Hmmm ... have to think about this some. Thanks for the input!
lesbentley ( ) posted Tue, 27 April 2004 at 6:34 PM
When adjusting the dial with the mouse cursor it only moves in increments of 0.001. The feild actually acepts much finer adjustments - I can't remember exactly how fine off hand - but you have to type them into the feild by hand, double click on the value above the dial, then enter the desired value using the keyboard. A pose file can also be used to enter fine values, e.g:
actor leftEye
        channels
                translateZ ztran
                        keys
                                k  0  0.000255
