Fri, Jan 24, 12:56 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 12:37 pm)
Subject: Windows XP & ZIP Files
S'Tomm ( ) posted Sun, 25 April 2004 at 1:32 PM · edited Fri, 24 January 2025 at 6:42 AM
Online Now!
I've finally got a new PC with enough horsepower to handle Poser. Now, I've got a new set of problems! First, Windows XP and ZIP files. Windows XP is supposed to have ZIP file handling built in; but, the documentation isn't very clear. For instance, if I download a prop in ZIP format, do I have to download it to a folder I've defined as ZIP before I can unzip it? Also, is there a ZIP application that works with Windows XP? I used NETZIP with my old machine and Windows 98; but, I understand that NETZIP hasn't been even tested with Windows XP.
TrekkieGrrrl ( ) posted Sun, 25 April 2004 at 1:34 PM
WinZip works fine. And as soon as it's installed it takes over WinXP's zip handling.
SamTherapy ( ) posted Sun, 25 April 2004 at 1:35 PM
Dunno about XP handling zips, I use Winzip.
Hehehe. Crosspost! :)
genny ( ) posted Sun, 25 April 2004 at 1:39 PM
I don't know about "Netzip" but I have XP and all I do is click onto the "zip" file and see what is in there. Then I copy it from there.........Not unzipping........but "edit" "copy all" and then create a new folder called what-ever and then I paste it all in there. From there I put the files where they need to go. I don't know if this is the easiest way to do it, but I save all my "zip" files to an external hard-drive, so when I want to use them, I load them this way.
ockham ( ) posted Sun, 25 April 2004 at 1:40 PM
WinRAR (from Rarsoft.com) also works very nicely with XP.
My python page
My ShareCG freebies
wheatpenny ( ) posted Sun, 25 April 2004 at 2:40 PM
Site Admin
WinRAR is also what I recommend, bec ause of some really useful right-click options it adds.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
bikermouse ( ) posted Sun, 25 April 2004 at 3:21 PM
This should about cover it: set up a folder for your downloads. when you dl the first zip point it to that folder in the dl dialog menu and it should point your other dls to that folder. (picts and documents you'll have to "point to" seperately.) to save as a zip file select what you want to zip and while your mouse is over the selection right click and select from the menu move to: compressed file. to check the contents without extracting them rightclick the zip and select open. to unzip contents of a zip file right click on the zip file and select extract. winrar is useful if the person you want to send zips to also has the utility, or are archiving for your own use.
sandoppe ( ) posted Sun, 25 April 2004 at 3:24 PM
The built in zipping capability works just fine on it's own. You download a zip file, right mouse click and select "extract all". It unzips into the same folder you downloaded it. No need for any other unzipping utility unless the file was zipped with stuffit. That is the only problem I've ever had. So....I use Stuffit (which is free I believe) to unzip stuff that my XP zip utility won't handle. I have XP Pro. Computer is about 2 years old.
TrekkieGrrrl ( ) posted Sun, 25 April 2004 at 5:17 PM
I'd never let Stuffit near my computer. It totaly messed up one I had at a time, taking over ANY kind of compressed file whether or not that cr...py program could actually handle it or not :o( It's a Mac proggie, made to extract .sit files which are Mac format (mostly at least, I don't know if stuffit can make a .sit from a pc) My best advise to Stuffit is to... stuff it LOL
sandoppe ( ) posted Sun, 25 April 2004 at 6:34 PM
Hmmm....that's interesting! Never had those problems. I downloaded Stuffit for Windows 7.0, designed for XP. Apparently there was a bug in an earlier version that this version fixed whereby file associations for supported file types were automatically assigned to StuffIt. Mine let's me pick what to associate it with. I can't remember what files I had to use it for....could have been .sit or .rar. Some of the vue freebies (even those for windows) are zipped oddly :)
Marque ( ) posted Sun, 25 April 2004 at 11:35 PM
If you use zip in XP you need to realize that it opens it like a folder, and if you move anything in the folder that opens, you remove it from the zip file. (found out the hard way). Your best bet is to get winzip. Then you will keep the files intact. It works fine in XP. Marque
sandoppe ( ) posted Mon, 26 April 2004 at 12:50 AM
All you have to do is "extract all" as opposed to double clicking on the thing. When you extract, you create a copy of the folder (just like winzip)and retain the integrity of your compressed file. Been using it for about two years now and never lost any content at all. Winzip is great.....I used it for lord knows how long when I had Win 9X, but there's just no need for it in XP.
wheatpenny ( ) posted Mon, 26 April 2004 at 1:11 AM
Site Admin
What I do with winRAR is, when installing it, on the file association dialog, uncheck "Zip", that way the WinXP default zip utility is still the default for zipping but I get the winRAR right-click extracting options that I find it impossible to live without...
Jeff
Hablo español
Ich spreche Deutsch
Je parle français
c1rcle ( ) posted Mon, 26 April 2004 at 2:44 AM
I've used Winzip since V1 so I disabled the zip function of WinXP, why bother with an inferior version when the original is still best?
Erlik ( ) posted Mon, 26 April 2004 at 8:41 AM
Attached Link: http://www.windows-help.net/WindowsXP/tune-14.html
The link describes the way to turn off the built-in ZIP support. Install WinZip afterwards, as people have already suggested.
-- erlik
Bobbie_Boucher ( ) posted Mon, 26 April 2004 at 9:12 AM
Attached Link: PowerDesk Free Version
Get the free version of PowerDesk Utilities. It's a great file manager, and includes a zip utility. I have PowerDesk Pro, and adimittedly don't use many of the extra features. The free version would likely satisfy most people.
simontemplar ( ) posted Mon, 26 April 2004 at 12:29 PM
Also if you would like a very intuitive desktop manager, yet light in use, I suggest purchasing Directory Opus licence. It's woth every buck you put in it. :) It has zip built-in support as well and works fine for me.
S'Tomm ( ) posted Tue, 27 April 2004 at 8:01 AM
Online Now!
Thanks for the tips, everyone. I'll see what works best.
