Tue, Dec 3, 9:39 AM CST
Renderosity Forums / MarketPlace Showcase
Welcome to the MarketPlace Showcase Forum
Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2024 Dec 03 2:56 am)
Welcome to the MarketPlace Showcase Forum. The Showcase Forum and Gallery are intended for all commercial related postings by active Renderosity MarketPlace Vendors only. This is a highlight area where our membership is invited to review in greater detail the various art products, software and resource site subscriptions available for purchase in the Renderosity MarketPlace.
Subject: Give your Renders some Action - Photoshop action, that is!
NiceNiche ( ) posted Mon, 26 April 2004 at 11:22 AM · edited Tue, 03 December 2024 at 8:44 AM
Want to turn your renders into line art? Nice Niche Productions proudly presents 11 different actions to do just that.
Here is an initial Poser render. (Yes, it was slightly postworked in Photoshop get rid of creases.)
NiceNiche ( ) posted Mon, 26 April 2004 at 11:25 AM
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=28055
And here's the result after running one of the ink actions. The image above has no other work done on it from the image in the previous post except for running one of my actions on it and saving it to a .jpg for the web.
(Please forgive the .jpg compression - at full size, the image is crisper.)
NiceNiche ( ) posted Mon, 26 April 2004 at 11:28 AM
Here's one of the 4 different actions that will produce a black and white, pen & ink effect. (It's one of my favorite actions of the pack.) Again, this image was created from the picture in post 1. All I did was run this action on it. No other post work was done.
NiceNiche ( ) posted Mon, 26 April 2004 at 11:36 AM
Run one of the black and white actions, then set it as the top layer. Change the layer blend to multiply.
For each item in the image, use a separate layer and color below the black/white ink layer. The black outline will always show above your color.
In this image, I used Ink2a as the top layer and set it to multiply, then ran the action again - yes, you can run the actions multiple times on an image - and used Ink3a just underneath, also on multiply, but only about 55% opacity. I then started coloring the Anime Doll using different layers for different colors. This took less than 5 minutes.
NiceNiche ( ) posted Mon, 26 April 2004 at 11:46 AM
All actions were tested in Photoshop 7 and Photoshop CS. I believe they will work in Photoshop 6 as well. (Everything I've read says actions in 7 work in 6 as well.) To use: just load your picture, load the action, and run it. Each action preserves the original, background layer so you don't have to worry about losing your work if you don't like that particular action for that particular render. Just delete the newly created layer and unhide the original background. You can also hide the new Ink layer, unhide the original background layer and run another action so you can see which ink effect you like best for your image. By the way, there are 11 actions, but most actions have 2 settings, one with a thicker line and another with a thinner line (the thinner lined actions all end in 'a'), so you really get 20 actions in all. I created the variants for smaller images so the line work doesn't overpower the image. These actions are now available at Renderosity, and should be released soon at Poser Pros as well. If you have any questions, please feel free to IM me or e-mail me. Enjoy! NiceNice Nice Niche Productions - Nice to the Nth degree.
lululee ( ) posted Mon, 26 April 2004 at 7:05 PM
These look fantastic. What a great product. cheerio lululee
