Mon, Jan 13, 2:14 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: Lizardman try
OwenF ( ) posted Wed, 04 October 2000 at 6:15 AM ยท edited Mon, 13 January 2025 at 2:03 PM
A try to make a RPG Lizardman. Using 3 figures (2 raptors for the head and the bottom, P4 man defautlt for the chest) and two props (Malis'shield and seatrident'Mea) Un essai d'homme lezard pour jeu de role. Sont utilis 3 figures (2 raptors pour la tete et le bas du corps, et le P4 man defaut pour le reste) et deux props (Bouclier par Malis et le trident par Mea) lizardman.jpg
bloodsong ( ) posted Wed, 04 October 2000 at 9:52 AM
heyas; wow! very nice! how is it working out? did you find the tutorial and make the figure work?
Binx ( ) posted Wed, 04 October 2000 at 11:56 AM
Kick ass!
OwenF ( ) posted Wed, 04 October 2000 at 1:43 PM
Hi bloodsong, i didn't find the tutorial for what i wanted to do. The lizardman actually call (need) 3 .obj files. it will be better if it were one only. I turn off visible some body parts. To make him walking correctly with walk designer or any other poses,i had to block some body parts like human hip, human abdomen and human neck. The bottom of the raptor is the parent. The human's hip is a child of raptor's hip, and the raptor's neck is a child to te human's neck. Sorry for my bad english ;-) Thanks again.
bloodsong ( ) posted Thu, 05 October 2000 at 9:59 AM
heyas; owen, that is what the tutorial is for; it tells you how to parent figures together into a new multi-figure character. you can probably go into the cr2 file and delete the parts you are not using, rather than having them there and invisible. if you want only one obj, you have to set the lizard man here into the default position, export the pieces, and then build a new cr2 for him. it is a lot of work, but sometimes it is worth it.
OwenF ( ) posted Thu, 05 October 2000 at 1:02 PM
Ok, I will try to make one obj as you describe. Thanks a lot for your help.
