Sacred, That's beautiful! :) I would possibly suggest some reflection on the table and a little less of a rough surface, but that's just an opinion; considering that the table appears to have a rough surface actually negates the possibilities for reflections. I would have raised the camera up some and pointed it down a bit, so the roses could be centered without obscuring the center plant. Hey! What about an un-level camera angle? Don't get me wrong, though.. it really is a gorgeous picture. :) Cheers, Mike
Bloodsong..there are already lights up in the wall scones...they r just dimmer than normal, because of the ambiance I was looking for. The walls are made up of a panel from the ArtRecon Collection gothic I believe :D Mike, the table is granite hence the rough surface. I haven't played a lot with the camera levels yet, so I was a bit hesitant to try it. Thankyou both for the comments and the suggestions...they r really appreciated:-) Sacred
Hey!.....that is a pretty nice composition :) As it is still in progress, I would not comment much as you mentioned that you have yet to play with the camera. Do note that I find the angle of view of the 'vase' containing the roses sitting on amrble table a little 'off'. It looks kind of "lack perspective". I think if you have the camera relocated up a little and have a low power added spot light with reasonable spread value may make a diffence. Try it. Bill
heyas; these recon architectural things are fantastic!!! and totally out of my budget. :/ i still gotta scrape together some money to get rhino. nope, can't take a vob, either. even converted, it's still their copyrighted mesh. ah well, i think with a little kpt stuff and laurie's terrain-architecture technique we can get some similar stuff... :)
