Fri, Jan 24, 6:30 PM CST
Subject: Is there a MAT to remove V1 -V2 textures?
rwilliams ( ) posted Sun, 02 May 2004 at 5:01 PM ยท edited Fri, 24 January 2025 at 1:16 PM
I am trying to find a MAT file or some way to remove all textures in a V1 or V2 figure? Is the something like that antwhere. Thanks in advance!
SamTherapy ( ) posted Sun, 02 May 2004 at 5:05 PM
Yup, there is. Can't remember what it's called, though. I think it's called "Utility Poses" or similar, in Freestuff. Failing that, make your own. Delete all the textures from your model, set all materials to white and save it using one of the free MAT creators.
Gearcy ( ) posted Sun, 02 May 2004 at 5:29 PM
For the benefit of a newbie, where would one find one of the free MAT creators? Thank you in advance.
mathman ( ) posted Sun, 02 May 2004 at 5:31 PM
Attached Link: http://www.maleposer.com/freestuff.shtml
If you are using Poser 5, you might find Mikenron's Clearnodes Paks useful.
EricofSD ( ) posted Sun, 02 May 2004 at 5:48 PM
If you are using Poser 5 you can go into the materials room and set a body part texture to white and then apply that texture to ALL.
rwilliams ( ) posted Sun, 02 May 2004 at 5:55 PM
Thanks for the replies. I am using Poser 4 Pro. Where do a find a free MAT creater? Thanks again!
nickedshield ( ) posted Sun, 02 May 2004 at 8:24 PM
Attached Link: http://koti.mbnet.fi/~ilaripih/MPEHome/
You can find Mat Pose Edit here. You can make your own texture removal by selecting the body part and applying no_map to it.
