Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
Dynamic stuff, I have no idea. Never yet used it, so I can't answer. Conforming clothes however, are a (usually) a doddle if you do the following: Load your figure. Add the clothes. Conform. They should (note - "should") follow the figure when you pose it. You may get some "poke through" but nowt as bad as your example above. Couple of things to note - You must use the correct clothes for your figure. Victoria 1 and 2 - and the original Stephanie - can share clothes. Michael 1 and 2 can share their clothes. Every other model has their own clothing. A heavily morphed model will often have problems with conforming clothes. You can get around it if the clothes have corresponding morphs to the model you're using. Otherwise, you can use a program such as The Tailor to transfer morphs to the clothes.
I've found that sometimes conforming clothing sometimes moves out of place when you pose the figure but most times if you hit conform again after you've moved figure1 the clothing will go back into place. For parts that poke through no mater what, you can just make invisible by going into parameters and unticking the visible box. 8) Catlin
I'd also suggest Parenting the clothing to the figure's Body prior to Conforming. This will insure that any Body scale changes in the figure will also be applied to the slaved clothing figure.
Also ,IIRC, keep in mind that any MT's in the clothing figure will revert to their last Memorized/Restored state when the Conform command is applied. (youse-guys please correct me if I bungled that one... too lazy to go confirm)
