Looks like an Eyecandy approach to the waterdroplet on the figure's body...if that is the case, use "masking" (most paint program has the feature) and 'eyecandy' them a small portion at a time...you have more control and can get the feel and looks you want It would definetly be more authentic. Try some "swirl" or "zig zag" behind her thigh to created a mild trailing movement of water. Very nice compositon but take away that terrain on the right or change it to a "work in progress" giant sand castle and throw in a plastic like spade and pail. Hmmmm...;-)...may be Mr Zyg Michael with a bold sunglasses lying on a tower with a "tan" look. Good work! Bill
Hello, Thanks for the comments. Tesign: Your're right. I used the new beta Eye Candy 4000 on the texture map. I'm still working on getting just the right combination. You know after you look at an image for so long, you kind of start missing some of the fine details. I'm just glad someone didn't ask me what kind of disease she had :) I know. The rocks look kind of cheesy. Working on that too. I might just eliminate them. The other thing I tried is the water. It is a terrain with a bitmap to try and get some sort of waves effect. I noticed the sort of motionless pose. Am working on the ripples around her legs. Again, thanks for the comments. hdrider
No good deed goes unpunished ...
Hi Hdrider, Eyecandy 4 is my next definite must have :) Go for it, do what you can to achieve the image you want. Be devilish with your post production skill. That's what 2D artist are born for. Btw, use a brush mask and mask a streaming flow from the part where the hair meets the back and apply a "glass" (have to play with the variables) on the water droplets. This would give impression of water streanm dripping down her back and the skin would have a "slimy" wet look. Good luck :) Bill
Bill, Thanks. By all means, please let me know! I downloaded the beta anyway, but I'm kind of hesitant to install it, because I once tried something similar and ended up corrupting Painter, and had to do a re-install. I really don't understand how plugins "work", and I don't like adding anything to an app's folder unless I know it won't wreak general havoc. ;) Cheers, Mike
Mike....after you unzipped, the exe file runs an install and request default is directed to Photoshop. Just ignore and select your path where your Painter is installed. From the Painter directory in MC, just select the "Plugin" for Painter. When you fire up Painter, you should see it under menu selection "effect". Good luck. Bill
heyas; i still think you should mix the skin texture with a water texture (possibly transparent, with an 'underlying material') in vue. if you want to use the eye candy drops you can, just make an alpha channel with them to use for the mixing function. then you can have different highlight and reflection settings for the skin vs the water. and also maybe use the alpha channel as a bump map.... there's a water texture in vue that has ripples in it... i've seen people line up objs in the water with the ripples to make it look very realistic... but not sure of the details. there was an old old old message here where somebody did that with the sea lion model. (maybe search for sea lion/seal?)
Hello, There are so may possibilities. I'm still working on different things. For instance, this version I used an object for the terrain with a section remapped for the ripple. The effect is not quite perfect but is a start. Maybe someday I'll know all there is to know about Vue, but I hope not. That would take all the fun out of it. Still Having Fun, hdrider
A couple of new techniques I'm trying. Comments? hdrider
