Just change the starting value for Scale in the pp2. The important line is the 'k' line, near the bottom of the scale paragraph. In this example it has k 0 1 which means that the value for Scale at frame 0 is 1.0; change the 1 to whatever it needs to be. For example, if 25% is the proper size, make the line k 0 0.25 ---------------------------------- propagatingScale scale { name GetStringRes(1028,5) initValue 1 hidden 0 forceLimits 0 min 0.001 max 100000 trackingScale 0.004 keys { static 0 k 0 1 } interpStyleLocked 0
My python page
My ShareCG freebies
If you want the paramiter dial of the scaled prop to continue to display a value of 100%, you can do this by using two scale channels, renaming the first channel and hiding it.
propagatingScale <br></br> {<br></br> name GetStringRes(1028,5)<br></br><br></br><br></br> forceLimits 0<br></br> min 0.001<br></br> max 100000<br></br> trackingScale 0.004<br></br> keys<br></br> {<br></br> static 0<br></br><br></br> }<br></br> interpStyleLocked 0<br></br> }<br></br> propagatingScale scale<br></br> {<br></br> name GetStringRes(1028,5)<br></br> initValue 1<br></br> hidden 0<br></br> forceLimits 0<br></br> min 0.001<br></br> max 100000<br></br> trackingScale 0.004<br></br> keys<br></br> {<br></br> static 0<br></br><br></br> }<br></br> interpStyleLocked 0<br></br> }
Attached Link: http://www.paradoxum.at
hi, I made a sword in Cinema 4d, did the textures with uvmapper, everything fits when when I import it in poser! but when I save it in the archive, it creates a pp2 file with all the obj-information, but I want a seperate objfile. I know how to edit this and make a link in pp2 file to the obj, but the problem is, when I now load the sword over the archive, the model is way to big. Is there a way to include a "resizing-information" in the pp2 file? why i do not resize the obj? I have my reasons :) but somehow it has to work, because when I import a obj in poser I have the option of resizing, so why not in a pp2 file? some advice? thanks
