Wed, Dec 25, 10:05 AM CST
Subject: Happy Mom Day!! And a question about UV mapper
Acedrake ( ) posted Sun, 09 May 2004 at 8:37 PM ยท edited Wed, 25 December 2024 at 9:55 AM
Hello gentlemen, Ladies and Mothers :)I have a question about uv mapper. I created an uv mapper text but cant seem to map corretly in poser. any idea why? And thanks and also Happy MOM DAY!!!
wyrwulf ( ) posted Sun, 09 May 2004 at 8:50 PM
Did you save the model after you remapped it in UVMapper?
Acedrake ( ) posted Sun, 09 May 2004 at 9:10 PM
Yes I did. First it looked all squished. It was a body suit for mike2. Trying to make a nightwing suit, painted and all but in poser when mapped, it only maps it to the left side.
wyrwulf ( ) posted Sun, 09 May 2004 at 9:25 PM
Show some images of the problem if you can. That would make it much easier to help.
Acedrake ( ) posted Sun, 09 May 2004 at 10:12 PM
Here is a try at the problem at hand
wyrwulf ( ) posted Sun, 09 May 2004 at 11:22 PM
Did you want the blue on both front and back? If so, either put it on both, or don't split the model when you map it in UVMapper. You should look in freestuff here to see if SnowSultan has a seamguide template for this.
chriscox ( ) posted Mon, 10 May 2004 at 5:46 AM
If you're using Poser 4 you'll need to delete the old geometry rsr so that Poser will create a new one with the new mapping of your remapped OBJ. If that's not the problem try opeing up the body suits CR2 file and make sure that it's pointing at the OBJ that you think it's pointing at. Chris Cox
Chris Cox
wyrwulf ( ) posted Mon, 10 May 2004 at 9:13 PM
Good one, Chris. I forgot about deleting the RSR.
