Wed, Jan 8, 4:15 AM CST
Subject: Need some help with Lynes bear mapping TIA
dlk30341 ( ) posted Mon, 10 May 2004 at 12:17 PM · edited Wed, 08 January 2025 at 4:07 AM
I have the maps for the bear & followed her directions to the tee & can't get the darn bear to map. I'm totally lost. I brought the figure into UVmapper....Imported new UVS...saved back out with the same OBJ name. The instructions say to put this into your character folder...well I did and obviously all that's there is OBJ...which obviously doesn't show up. I've tried this several different ways & I can't get anything to work. I'm so frustrated.....:( TIA
dlk30341 ( ) posted Mon, 10 May 2004 at 12:19 PM
I should add..using UVMapper Pro & PPP
byAnton ( ) posted Mon, 10 May 2004 at 1:08 PM
the obj goes into the same folder as the original obj, usually in the Geometries folder. If there is an rsr in the geometries folder, delete it. You may have to close Poser before doing all this.
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
dlk30341 ( ) posted Mon, 10 May 2004 at 1:14 PM
hmmmmmmm...I tried that.....:( Didn't work. I have sent off an email to her...but I'm impatient ;)....
dlk30341 ( ) posted Mon, 10 May 2004 at 1:27 PM
As stated above....I didn't remove the old OBJ file....DOH!!!!!
byAnton ( ) posted Mon, 10 May 2004 at 1:28 PM
Explain exactly what happens or is not happening when you click on the cr2 to laod it. Is there any message at all? Sometime you have to load the cr2(nothing happens) then close Poser, restart it and then load again.
dlk30341 ( ) posted Mon, 10 May 2004 at 1:40 PM
Anton..looks you were posting at the same time I was LOL.....I got it.....Massive brain fart!!!!! on my part.
byAnton ( ) posted Mon, 10 May 2004 at 1:42 PM
odeathoflife ( ) posted Mon, 10 May 2004 at 6:45 PM
open the cr2 in wordpad and see if it is pointing to the right obj file, if it is not just fix the path and save it ( like bear2.cr2 ) and see if that works.
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
slinger ( ) posted Fri, 14 May 2004 at 6:35 PM
Attached Link: http://www.planit3d.com/index.htm
If you drop by PlanIt 3D you can ask her yourself, she mods there :)
The liver is evil - It must be punished.
