Sat, Feb 15, 1:39 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Subject: Absolute File Path problem
IcyFire ( ) posted Thu, 13 May 2004 at 7:01 PM ยท edited Thu, 13 February 2025 at 1:38 AM
Is there anyway to change the file locations for textures in a PP2 or PZ3 file? For exp, the prop file has textures located at D:/My files/Poser/textures but I have no directory like that. Any help is appreciated.
Ajax ( ) posted Thu, 13 May 2004 at 7:14 PM
You can do it by hand with a text editor, but the easiest way I know is to user either Correct Reference (which is free) or the substantially better Correct Reference Pro (from the store). Both are by Hogwarden.
neilp ( ) posted Fri, 14 May 2004 at 10:19 AM
To do it by hand follow these steps. 1. Open the PP2 or PZ3 file in wordpad. 2. Search for the word "material" 3. On these lines you will see the path that Poser will try to locate the texture from. 4. To make this path compatible with all versions of Poser use the following syntax : :Runtime:textures:texture folder:texture.jpg remember whan resaving the file to check that wordpad has not added ".txt. to the end of the file name. If it has simply rename the file and remove the ".txt" Hope this helps.
