Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Feb 17 3:50 pm)
He is good looking, but his main selling point is that he can take M2 clothes but use M3 skins and morphs, right? M3 to M2 can do that. The skins and head morhs anyway.(I don't know if M3toM2 takes m3 body morphs or not) Does he have other advantages over that model or is he mainly for people who have not gotten M3 yet. (I don't know if M3toM2 takes m3 body morphs or not) Could someone Please do a comparison between the two (M3toM2 and Daniel) Thank you.
First, he's got a modified geometry (like the Freak), and is Unimesh. The mesh mods are so his base is very close to M2. He takes all the M3 injection morphs, unlike M3toM2. Nothing special needs to be done to do that. He also takes Freak injections, and Puck injections. He wears most of M2 cloths with very little tweaking. When M3 came out, a lot of people complained that he couldn't bulk up well, and that M2 made for a better muscular figure. The also wanted to be able to use their M2 clothing. The M3toM2 figure that came with M3 was limited in that it couldn't take the M3 injection morphs. The Aeon hero provides the solution. Why the Aeon Hero? To add versitility to the male line. Old cloths fit, he takes M3 injection morphs, since his base is bulkier than M3, and his base face is stronger, he provides a strong alternative to the base M3 without the overdone look of the Freak.
![file_109288.jpg](https://live.cdn.renderosity.com/forum/threads/1781788/file_109288.jpg)
Daniel, the Aeon Hero. In a time of need, a hero will arise. Specifically designed to appeal to the M2 lovers out there, there's finally a figure who answers your prayers. Daniel has been built carefully designed to create a figure that fills the demand for an M2-like figure that nonetheless takes M3 textures and morphs (the whole body, not just the face). Built with compatible joint parametres to M2, most M2 clothing can be worn with little or no fiddling. Only skintight clothes (like the bodysuit) defy this, and hiding body parts gets past even that limitation. Even M2 body magnets have proven compatible! Bring those old clothes back to life! With the ability to accept most M2 poses, and to wear M3, Freak and Puck textures and injection morphs, and to slide easily into most M3 poses (and most other Mil Poses), Daniel, the Aeon Hero will delight you and inspire you. Built off of the DAZ Unimesh, this product's geometry comes in the form of RTE difference files which contain only the derivations and not the original unimesh, and as a result requires DAZ's Michael 3 figure to already be owned by the user. However, once generated the figure geometry is a standalone mesh of its own with it's own custom CR2 and support files. This approach allows XFX3d/Dodger (creator of She-Freak and Puck) and PoserPros to bring you high-quality Mil3-mesh-based figures in the form of what essentially amounts to a simple kit, making your existing M3 purchase even more valuable to you! Daniel is distributed in 'Kit' form so that it may be sold outside of DAZ's stores. Two options are provided to the user to generate the mesh -- the preferred RTEncoder file to be decided from M3's geometry, or a seperate, completely-within-Poser new object export method especially for Mac Users.
