Attached Link: http://www.schlabber.org/
The models do have some limitations and with that pose you're going to run into quite a few of them. You'll probably have to settle for something similar but not exactly like that pose. I can see trouble ahead with the upper legs and the shoulders in that pose.Give Schlabber's tutorials a look before you give up. And if you do give up, he's one of the best creators of poses around, so he'd probably be able to help you out.
See given link.
Hope this helps,
Unzipped
Message edited on: 05/19/2004 13:53
You gotta change the proportions to achieve that pose. The head needs to be larger, the torso needs to be shorter, the abs narrower, the limbs longer. The left buttock and left thight needs to be set beyonds it's dial limits. The right shoulder will present some problems, since even in the illustration it's bent such a way that the joint looks kinda flat. It's possible to create a similar pose, but you need to do some postwork on the render. JV
Software: Daz Studio 4.15, Photoshop CC, Zbrush 2022, Blender 3.3, Silo 2.3, Filter Forge 4. Marvelous Designer 7
Hardware: self built Intel Core i7 8086K, 64GB RAM, RTX 3090 .
