A single GIF file can do animation as well as transparency, which would avoid the need for Flash if that's your aim. There are a variety of tools which will assemble stills into an animation for you - I use Animation Shop which comes with Paint Shop Pro, and there are various free ones to be had on the software download sites.
Here's the deal. I've been hired to create a figure in Poser for a series of animations. These animations will be put on web pages. The content BEHIND the animation has to be visible, so the animation itself has to have a transparent background.
The best way I have found to do this is as follows:
Render the animation out of Poser as a series of still images.
Bring the images into Photoshop, and export them as GIF89A files, with the background color made transparent.
Bring these GIFs into Flash, and re-assemble them into a movie.
Export this movie using Flash's Transparent Window Mode (Publish Settings dialog box).
Build a table having a background image consisting of whatever screenshot I need.
Position the Flash movie in this table using CSS.
It's a rather complex algorithm, but it has the advantage of working.
My question is, does anyone have a better way of doing this? My client wants to be able to change the screenshot from time to time, without necessarily changing the anmation -- so there is no point in putting the screenshot into a layer in Flash. Bigger file, anyway.
I'm posting this in the Photoshop and Poser forums just to see what sort of response I may get from different communities. Thanks in advance, folks!
Message edited on: 05/27/2004 10:10
