Tue, Feb 25, 11:07 PM CST
Subject: mat. files
cableguy223 ( ) posted Mon, 31 May 2004 at 9:46 AM · edited Thu, 30 January 2025 at 12:00 AM
how you change bmp. files to mat. files ?
judyk ( ) posted Mon, 31 May 2004 at 10:33 AM
Start up Bryce, create any object (sphere for example). Select the sphere, click on the M in the little stack of options that appears beside it, which takes you into the materials lab. In the mat lab, put a bead in the first column against the diffuse option, so that a default texture appears on the right. Now click on the little P under the texture, to turn it into a picture object (you should get leo as default), then click on the bead above leo's head, to take you into the picture editor. Click on an empty square in the pic editor; this opens an explorer window. Find your .bmp file and double-click on it to load it in. Create a bump channel for it if you want to, then click on the tickmark to close the pic editor. Back in the mat lab, adjust the settings on your new material as required, then click on the little right-facing arrow to the right of the preview window. This will open your material library; decide which category you want to add your new material to, then click on add at the bottom of the window, give the mat a name and description, click the tickmark to save it, click the tickmark to close the material library, and Hey Presto! your .bmp is now a Bryce .mat!
pakled ( ) posted Mon, 31 May 2004 at 11:26 AM
thanks..now I'm dangerous..;)
cableguy223 ( ) posted Mon, 31 May 2004 at 11:50 AM
this has been a great help, Thanks
ddruckenmiller ( ) posted Mon, 31 May 2004 at 12:58 PM
@pakled - Just take your meds and in 20 minutes everything will be fine - don't forget the hotline if you need it. 8)
matrixmode ( ) posted Mon, 31 May 2004 at 4:02 PM
Thanks! Now I'm dangerous too! mwahahhahaha :P
"Simplicity is the ultimate sophistication." Leonardo da Vinci
AgentSmith ( ) posted Mon, 31 May 2004 at 6:04 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1683688
Along with what judy states there, if you want a picture of step by step, see link. AS
cableguy223 ( ) posted Mon, 31 May 2004 at 10:02 PM
I'll check it out , thanks
pakled ( ) posted Tue, 01 June 2004 at 8:54 AM
Brycetech's web site (I think it's just .com..;) has a very long, detailed, covers-all-the-bases tutorial that I really Should look at and try out..;) while it's still there..
AgentSmith ( ) posted Wed, 02 June 2004 at 6:32 AM
yesyesyesyes
cableguy223 ( ) posted Wed, 02 June 2004 at 3:40 PM
Is Bryce leaving soon ? Hope not
AgentSmith ( ) posted Wed, 02 June 2004 at 7:31 PM
Who knows? Some time ago it was reported that his site wouldn't come up any more, (and it wouldn't) for a week or more. Brycetech doesn't actually host the site himself, someone else does that for him, I guess the bandwidth is crazy. Like any site, it could dissapear anytime, just like the Bryce Forum Gallery (http://www.watchfuleye.com/brycelobby.html) Which he has now even taken offline the galleries he said he was going to be able to keep up. ;o( With any site, see it and save it while you can! AS
cableguy223 ( ) posted Wed, 02 June 2004 at 9:56 PM
when I goto the links in Bryce I get zlich, guess there gone, but since I have your attention maybe you can tell me why whenever I move the trac ball I stretch the models way out of proportion.
AgentSmith ( ) posted Wed, 02 June 2004 at 11:41 PM
That is weird...the track ball shouldn't have any effect on a mesh, it should only affect the camera movement. AS
