Wed, Dec 18, 4:56 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 18 2:45 pm)
Subject: Extract a prop?
pbguy1211 ( ) posted Fri, 04 June 2004 at 12:10 AM ยท edited Sat, 17 August 2024 at 4:15 AM
I downloaded a poser model, the model comes with a few props attached that are movable and such. Is it possible to extract these from the model and save them as individual props? I'm running P5 if it matters. Thanks. -pb
wyrwulf ( ) posted Fri, 04 June 2004 at 12:16 AM
Select the prop, open the prop library folder of your choice and save.
stonemason ( ) posted Fri, 04 June 2004 at 12:26 AM
& use "select subset" to pick what props you want to save(I think that relates to P5 aswell)
Cg Society Portfolio
pbguy1211 ( ) posted Fri, 04 June 2004 at 1:06 AM
ty
EnglishBob ( ) posted Fri, 04 June 2004 at 5:37 AM
Don't use 'select subset' if you're only saving a single prop, and you want it to be a smart prop (automatically remembering its parenting information). 'Select subset' is necessary only if you want to save several props as one library entry - but it cancels any smart proppedness.
