Firstly look in you Windows Recycle folder, if you have not emptied that you can retrieve it from there. If you deleted it from within the program however you will need to reinstall from the CD. You will not loose any of your custom files provided that they have different names to the ones that came with the program. Hope this helps.
I deleted the stick figure female from my poser on screen files Likely accidentally, and I can guess why. When I click on a library figure, I want a check box to appear that says "You are trying to delete your ... and the name of the model." Preferably with a check box that must be checked AS WELL AS clicking the "yes" before the Poser will delete the model.
I deleted the stick figure female from my poser on screen files, and would like to use it again. I still have the geo. file ,but no figure file. How can I bring it back into poser so I can use it. Is there a way to import it? The files for obj and rsr are still in the geo folder. skee
NOTE: No trees were killed in the sending of this message, but a large
number of electrons were terribly inconvenienced.
