I cannot possibly imagine how these thoughts would even remotly apply, but since windoze is a mysterious creature... 1. have you run a registry correction tool yet like Norton? Is the registry pointing files to the original drive? 2. there is a free tool called "correct reference". this should have NO effect on your problem, but worth a try. 3. read all the tuts on linking libraries. I've found that the procedures are different and the one in the Poser manual did NOT work for me but one of the website ones did. If you need help, IM me and I'll go searching, I'm sure I have it somewhere. 4. do you have more than 100 folders in your directory? If so, SR4 of P5 needs to have a manual xml change made to it so that they show up. I don't know about sr4.1. 5. if you uninstall and then run a registry cleaner then reinstall fresh, go to the latest SR before opening Poser. See if that helps. 6. have a cup of coffee, a realy YUPPIE type cup of coffee. You know, the kind of coffee that costs more than a fine dinner at a five star restaurant. Then repeat steps 1-5 above.
If you're in Poser5, you have to go to the top of the Directories tabs and use the check mark or + (I can't remember which) to add new directories. I just moved my runtimes from a groaning 120 gig external hard drive to an almost half full new 200 gig external hard drive. After moving the files, I had to add them back in within Poser5.
thanks everyone that gave advice on how to re-install my poser..but now i have another problem....i installed poser on my "F" drive...works great....i went to link runtimes from the other drive...the folders all show up in the runtime...but wheni click on the tab...there is nothing there...i can see folders when i look directly in the directories but in poser...just empty not even the man shrugging his shoulders...anybody got a clue...thanks in advance..
