Forum Moderators: Staff
the short answer is you cannot. but basically the bump map is a 8 bit b/w image of the original texture. so what i do is bring up the text i want to work with, change it's mode to grayscale ( I use photoshop5 ) and then adjust the bright and contrast till it looks the way i want it. ( the lighter the color the hight the elevation, the darker the lower) and then "Save as" XXXXXbump.jpg then in poser i'll load the xxxxxxbump.jpg , poser will ask to convert it and Vviola! it works pretty well.
How do I import Poser bump maps such as Michael's and Vickie's into Painter 3D to edit them along side of the texture maps?
