Mon, Jan 27, 1:08 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
Subject: looking for talon morphs (for v3 nails)
ErrantMinion ( ) posted Fri, 11 June 2004 at 10:06 AM · edited Sun, 26 January 2025 at 7:20 PM
Someone can tell me where can I find tallon morphs for V3 nails? Ty
mofolicious ( ) posted Fri, 11 June 2004 at 3:19 PM
ME TOO!
TrekkieGrrrl ( ) posted Fri, 11 June 2004 at 3:25 PM · edited Fri, 11 June 2004 at 3:25 PM
Hmm I thought they were included? there are long nails morphs for V3 at least. They're located in the BODY section.
Message edited on: 06/11/2004 15:25
igohigh ( ) posted Fri, 11 June 2004 at 9:16 PM
Long, curved, sharp talons; that's what she needs! And gargoyle feet morphs too, perhaps one with a heel toe as well!!!
lhiannan ( ) posted Sat, 12 June 2004 at 4:35 PM
If you attach a little magnet to the tip of each finger, draw it out and then rotate it, it should pull the finger out talon-like. Taking Poly's and turning them into useless curves is about all I've ever got the magnets to do in Poser.
I've attached a pic showing what a quick minute can do.
igohigh ( ) posted Sat, 12 June 2004 at 6:17 PM
How do you keep it from pulling one the finger as well since the nails can't be selected separte??
lhiannan ( ) posted Sat, 12 June 2004 at 8:52 PM
You do pull on the finger as well (gosh, that sounds like the start of a bad joke...snicker). The trick is the scale the mag zone (the "circle") so it only hits the nail part, or mostly so. If you look at my example, you can see the grey of the finger traveling along the edge of the nail. Fiddling with the mag would reduce this and unless one is doing an extreme closeup, I think even my quickie morph would be servicable at this point.
FyreSpiryt ( ) posted Sun, 13 June 2004 at 9:50 AM
You can create a group of just the fingernail using the grouping tool. Create a new group, then add material and add the fingernail material. Then you can create a magnet that only affects that new group.
igohigh ( ) posted Sun, 13 June 2004 at 3:41 PM
Thanks FyreSpiryt, I was just thinking along the same line since it does have it's own material zone.
