Sun, Jan 26, 3:29 PM CST
Subject: INJ Poses
mathman ( ) posted Fri, 11 June 2004 at 7:42 AM · edited Sun, 26 January 2025 at 3:24 PM
Hi all, Another question !! :) For a unimesh model, why is it that some INJ poses require loading all of the (body or head) morphs, but others don't ? I'm asking this because I purchased a set of faces for David (they are actually INJ/REM poses), and I couldn't get any of them to work unless I first of all loaded up all of the head morphs (which is time-consuming) ..... But I've had other INJ poses which could be injected without having load other morph sets... Thanks in advance. regards, Andrew
oilscum ( ) posted Fri, 11 June 2004 at 9:09 AM · edited Fri, 11 June 2004 at 9:22 AM
Open one of the files with a text editor and take a look inside. I can't stress using text editors enough! Where is the "readScript" path directed? Are unnecessary calls for INJections listed (i.e., ones that aren't required for that particular face)? Delete them and "save as..." a copy with a different name. I'm reasonably sure you can do the same with unnecessary head channels, too. Do you really need that CHIMP head channel in there?
Message edited on: 06/11/2004 09:22
mathman ( ) posted Fri, 11 June 2004 at 5:17 PM
Thanks for replying, oilscum. I opened up one of the INJ pose files, it was very compact and there were no unnecessary references i.e. there was a 1:1 correspondence between the readScript calls and the segments under actor:head. FWIW, there was also an embedded comment saying that it had been created by Injection Magic. Having said all this, it still didn't want to work unless I first loaded up the head morphs. I found this out by trial and error - if I tried to load up the pose without loading up the head morphs, the Poser session would hang - but if I loaded up the head morphs first and then applied the Pose, it would work. regards, Andrew
SWAMP ( ) posted Fri, 11 June 2004 at 7:44 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1721743
mathman,As it turns out,Injection Magic is a good program for personel use,but for content makers it has problems. It corrupts files where they will work for some people,but not for others. Take a look at the comments by lululee and also Jim Burton at this linked thread. I would either return your purchase or see if they can be replaced with workable files. SWAMP
