Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2024 Nov 24 5:00 pm)
Wonderful product, Chris! This is just fantastic!
Nancy Deer With Horns
Deer With Horns
Native American Indian Site
I did a quick test with the poses using Victoria 2. They work ok with some minor tweaking. V2 is definitely skinnier than V3 so if say the V3 pose has her hand touching her waist, the V2 pose will have a space and I had to twist the shoulder. For another pose, because for V2 the neck has two parts - neck and upper neck, the chin might enter the shoulder in some poses and will have to be tweaked. But I can say that other than these types of tweaks, the Poses look nice on V2 with a little more work.
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=28975
Introducing a versatile pose set that can help you generate more poses than normal. Included are 84 Partial Poses: 21 Lower Torso poses (From the Hip down) and their flipped versions; and 21 Upper Torso poses (from the Waist up) and their flipped versions. Although Upper Torso pose A (left) is optimized for Lower Torso pose A (left), for example, you can mix and match upper and lower poses to create over 1,700 different poses! Important: It is important to note that not all combinations are desirable but you might produce some interesting results! You can even use these Partial poses with other poses not in the set if you want to change the top or bottom of a pose. Tweaking may be required. Best results usually can be obtained when you tweak the abdomen, shoulder and collar for some combinations. The poses are optimized to match their alphabetical counterpart. So what is a Partial Pose ? A Partial Pose is a pose that affects only a certain portion of the body. CONTENTS There are 84 Partial Poses which includes: 42 Quality Poses for Daz Victoria 3 Lower Body (From the Hip Down) (21 Right & 21 Left) 42 Quality Poses for Daz Victoria 3 Upper Body (From the Waist Up) (21 Right & 21 Left) BONUS!! 5 Hand Poses for V3 1 ReadMe 1 License 3 Preview Images of the Poses All poses have been saved such as to not affect your character settings. Special attention was given to finger positioning, eyes and arms. All files come with Pngs and Rsr versions.
