What version pf Poser do you use? P4, PPP or P5? In P5 there might be a problem with doublesided polygons (two polygons in the same place). P5 gets in trouble deciding which side is forward. You can apply a slight displacement (very slight 0.01 or so) in the displacement slot. Mybe it cures the problem - maybe I'm totally wrong :-) Willy
could you show the wireframe mesh from the same camera angle? If the polygons in that area are quads, then you have a non-planar quad with a concave profile. That can be cured by triangulating the mesh. If you are getting this on a mesh that is already triangulated in that area then it might be a degenerate polygon, co-planar polygon or back-facing polygon.
