Tue, Jan 21, 1:41 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
Subject: Mihai Hair
Niles ( ) posted Mon, 14 June 2004 at 8:54 PM · edited Mon, 20 January 2025 at 8:03 PM
Anyone have this hair for M3, and is it a problem to render? Thanks Niles
xoconostle ( ) posted Mon, 14 June 2004 at 9:25 PM
I have it, it's excellent. I use it in P4/PP with no problems, however, I seem to recall that there might be some problems with rendering it in Firefly mode in P5. If anyone can help out with that, please do. If you get it, be aware that it can also be used to simulate a close-cropped hair prop. Just make all the upper layers transparent and leave the skullcap alone. I hope Neftis will be making some hair for David. All her hair products look great.
Niles ( ) posted Mon, 14 June 2004 at 10:05 PM
Thanks, I have it and Poser5, and it locks up ...with Firefly, I like the hair, hate M3, but thought I would give it try. No luck rendering so far.
semidieu ( ) posted Tue, 15 June 2004 at 5:56 AM
Attached Link: http://www.poserpros.com/forums/viewtopic.php?t=17060
I saw somewhere a little trick to render the Mihai Hair in Poser5... I didn't test it... Hope it helps... (and works!)
tonymouse ( ) posted Tue, 15 June 2004 at 7:28 AM
If you follow that thread there are instruction to seporate out the hair into "sections and put it back together, in Mapper, and yes it works. I did it to the mahai and julian hair, both had the same problem. fixed now. I need to sit down and do it to a few others but haven't had the time.
mstudios ( ) posted Tue, 15 June 2004 at 9:37 AM
What was recommended if you don't have UVMapper is: you could do the same without UVM: - import the object in Poser (all boxes unchecked) - select this object and open the GroupEditor - now, do for all parts: New Group .. include material (choose it from the list) - when you have done this for all 4 parts: spawn props - close the GE Now export (with the standard settings) the 5 parts (select them from the hierachie window) as a single object. You should have a re-organized new object for this hair. Everything else is the same as described above
ronstuff ( ) posted Tue, 15 June 2004 at 6:38 PM
What I don't understand is why the merchant has not come out with a FIX for the hair. This is actually a BUG in the mesh and it is sloppy modeling practice. The fact that it works in Poser 4 is not proof of anything except that Poser 4's simple rendering engine is more tolerant of sloppy geometry.
Ethesis ( ) posted Tue, 15 June 2004 at 7:16 PM
No kidding. I even bought this one ... well, maybe it will get fixed eventually.
TIMMYLYNN ( ) posted Sat, 15 January 2005 at 10:32 AM
Hi All, I am trying to use it in Poser5 since DAZ gave it away. Now am trying to use. There is a supposed fix posted on the DAZ site but I tried it. It involves doing as mstudios suggest but I tried that exactly as they instructed and it still locks up the renderer. There was a menu that popped up at the end of the procedure that was not mentioned in the fix.....there where a couple of boxes checked and the rest unchecked....there was no mention of what those settings should be. The choices where something like ....names polys as separate ......name polys as one.....I can't recall and I'm not trying it right now but if anyone can help the hair does look really nice....I would love to use it..... Regards, TIMMYLYNN
semidieu ( ) posted Sat, 15 January 2005 at 11:53 AM
Attached Link: http://www.runtimedna.com/messages.ez?Form.ShowMessage=90429
Here is a tutorial for it (runtimeDNA). I used it and it work fine !!!
Ethesis ( ) posted Sat, 15 January 2005 at 12:01 PM
Quote - What I don't understand is why the merchant has not come out with a FIX for the hair. This is actually a BUG in the mesh and it is sloppy modeling practice. The fact that it works in Poser 4 is not proof of anything except that Poser 4's simple rendering engine is more tolerant of sloppy geometry. [end quote] There is a patch (I got it from the author). The real issue is an issue with DAZ. Sigh. Right now I just render in P4 as the patch is still pretty slow.
