Sun, Jan 26, 3:01 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: How do you use the Origin Poser Python command?
smiller1 ( ) posted Thu, 17 June 2004 at 5:37 AM · edited Sat, 25 January 2025 at 11:52 AM
This returns all zeros but the current actor is not at co-ordinates 0,0,0 ....
import poser
scene = poser.Scene()
act = scene.CurrentActor()
xyz = act.Origin()
print "xCord: " + str(xyz[0]) + " yCord: " + str(xyz[1]) + " zCord: " + str(xyz[2])
Message edited on: 06/17/2004 05:40
stewer ( ) posted Thu, 17 June 2004 at 7:34 AM
IIRC, the Origin describes an actor's position when the figure is zero'd. If you want the absolute position of an actor in world coordinates, try the WorldDispaclement().
smiller1 ( ) posted Thu, 17 June 2004 at 7:42 AM
Thank you stewer, that's just what I needed.
