Tue, Jan 28, 11:46 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Subject: Prop or figure, which is best for jewelry?
imagica1 ( ) posted Wed, 16 June 2004 at 6:08 PM ยท edited Tue, 28 January 2025 at 9:57 AM
Hello there everyone, I have a real quick question.... If you make something like a necklace, would it be better to distribute as a prop file or a conforming figure? And what are the benefits of either one of them over the other? Thanks in advance!! Imagica
-Yggdrasil- ( ) posted Wed, 16 June 2004 at 6:21 PM
Prop I think would be best for something small like a necklace. A figure could conform if it were something like a body necklace (going from the nexk to the legs or something, that way it flows along the body the whole time). Props are small, efficient and don't need to be conformed or what-have-you. Remember with props, extract the geometry from the prop file and have the .pp2 (prop file) call the .obj (object file) for the prop. Also, parent the prop before saving it, that way it will automatically be smart-propped to an area... say the neck, for a necklace. Anyone can use the dials to adjust positions if they need to. If possible, try to parent it to a standard barebones figure as it loads in at default. That will require the least amount of adjustments from people that use your props. Conforming figures don't need to be positioned just-right to make them work, but again, something simple like earrings or a necklace (in their purest sense) don't make good conforming figures. I guess an example of making something a conforming figure is Kozaburo's popular MK3 Hair. It comes as "hair" and "figure". The figure could be conformed so that it automatically zaps to the top of Vicky's head and when you move the left shoulder, her hair that hangs on that side would move along with it. That's a good example of deciding whether to make something conforming or not. Although I believe the hair does not perform as that, if memory serves me correctly.
ronstuff ( ) posted Thu, 17 June 2004 at 2:37 PM
On jewelry, definitely as a SMART PROP (saved to the library while it is positioned and parented to the figure). The main reasons for using the figure format (cr2) for props is when you have several parts of the prop that need to be able to move independently but relative to their parent. All "Articulated Props" are figures. Static props don't need to be figures.
imagica1 ( ) posted Fri, 18 June 2004 at 6:20 AM
Thank you so much for the information! I had made my piece as a smart prop and was thrilled when it was not recommended to create a figure for it! Again, thanks for such quick responses, yall are great! Imagica
