Wed, Dec 4, 3:34 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 3:06 am)
Subject: Injection morphs in P5
Dore ( ) posted Mon, 21 June 2004 at 12:50 PM ยท edited Fri, 16 August 2024 at 3:31 PM
Many of the injection morphs that I have don't work in Poser5, yet others do. Is there an easy explanation why not? Thanks for any replies.
PapaBlueMarlin ( ) posted Mon, 21 June 2004 at 1:13 PM
  1. Did you move anything in the !DAZ folder? 2. Do you have multiple figures in the scene (to cause crosstalk)? 3. What morphs are you injecting?
Dore ( ) posted Mon, 21 June 2004 at 1:20 PM
  1. I am unsure what you refer to as the !DAZ folder. If you mean did I move into the indicated runtime etc. folder the stuff purchased from DAZ and/or downloaded from Renderosity free stuff, the answer is "no, I did not change the indicated folders". 2) No. 3) Thinking back now I think the ones I have had trouble with are V3 face morphs, either expressions or appearance. Thank you for your response, any thoughts as to what I am doing wrong or my problem will be much appreciated.
PapaBlueMarlin ( ) posted Mon, 21 June 2004 at 1:24 PM
Try this. Close Poser and reopen. Add V3 to the scene and then go to the folder where you add all of V3's expressions. Tell me if the morphs don't load...
Dore ( ) posted Mon, 21 June 2004 at 3:14 PM
Thank you for your futher comments. I started P5 from scratch, added V3 SR1 from DAZ People, and then tried to inject the V3 Anguish morph (don"t recall where I got that) from Poses - hung machine (little watch never goes away, eventually get "Poser Not Responding". Quite P5 and started over. Did same thing with same results with Trinty and !Faith FreeGal V3 morphs both obtained from Renderosity Free Stuff. A quick look through the libraries suggests that I think all the injections morphs I have purchased from DAZ work, didn't have time to see if there were any purchased injections morphs from Renderosity Marketplace and check whether any such work or not. Any suggestions?
Puntomaus ( ) posted Mon, 21 June 2004 at 5:48 PM
Have you only updated V3 or did you update the head and body morph packs as well?
PapaBlueMarlin was talking about the !DAZ folder under Runtime/libraries (see screenshot). This folder must be in your default Poser 5 runtime.
Dore ( ) posted Mon, 21 June 2004 at 8:03 PM
Oh, I got it. Yes I do have the Body and Head files under !DAZ/Victoria 3. Just for the heck of it I dug up my download archive and reinstalled the V3 Head and Body morphs. That didn't change my inability to use the three morph injections listed above. Thank you for your thoughts, if you have any further idea as to a cure or work around I would certainly appreciate them.
