Sat, Jan 11, 1:08 AM CST
Subject: Michael's head on a P4 body
shadowcat ( ) posted Thu, 19 October 2000 at 11:27 PM ยท edited Sat, 11 January 2025 at 12:47 AM
I don't remember where I saw this as a topic but I figured out how to do it and retain the facial morphs. make a prop of mike's head, then replace P4's head with the prop. To get the morphs use morph manager to copy the morphs from normal mike onto your new hybrid. The only problem I have run into is getting the neck alignment right and setting the eyeballs.
picnic ( ) posted Fri, 20 October 2000 at 8:40 AM
WarriorDL has already done this and posted the model. Its called Bobby. He also has the Vicky/P4 called Pollyette.
shadowcat ( ) posted Fri, 20 October 2000 at 9:43 AM
I couldn't find it anywhere, I even went looking for any mention of this. But that's ok, I've only had poser a month, so I figure I'm doing pretty good for a beginner.
picnic ( ) posted Fri, 20 October 2000 at 10:18 AM
Oh, nothing intended. You are going fine, but I expect WarriorDL's is either on his own page now or on the SciFi forum.
chaosphaere ( ) posted Fri, 20 October 2000 at 12:12 PM
Out of curiosity, what is the point of pasting Vicki or Mikey on a p4 stock figure? What does this do? Will it enable me to use their head textures? Chaos
Tribe ( ) posted Fri, 20 October 2000 at 3:38 PM
Chaos, The reason the head the Michael head is grafted onto the P4 body was that intially there was a major shortage of clothing and skin texture maps for Michael. And I guess this also applies to Victoria when she was released. Yes you can use the head texture as they are seperate from the body textures, unlike the original P4 models which had one. Tribe.
WarriorDL ( ) posted Fri, 20 October 2000 at 8:19 PM
Attached Link: http://www.3dposer.com/
http://www.3dposer.com/ Go to the Characters/Basic section. You will need Mike (if you're getting Bobby) or Vickie (if you're getting Polly or Paul), as well as ObjACTION Mover (in Freestuff).
picnic ( ) posted Fri, 20 October 2000 at 8:22 PM
Also, you will need to adapt either a P4 head texture to Vicky and Mike OR adapt a Vicky or Mike head to the P4 bodies. Chaos, there are a great deal of clothes for both the P4 man and woman and this gives one a great deal of latitude using these clothes until there are a lot for Vicky and Mike. Being able to use those terrific heads for Vicky and Mike are a terrific compromise for the time being. Also--you can adapt any P4 hair to Vicky and Mike with little problem.
picnic ( ) posted Fri, 20 October 2000 at 8:23 PM
I meant to say a Vicky or Mike texture for the P4 bodies.
chaosphaere ( ) posted Mon, 23 October 2000 at 11:57 AM
I wasn't aware there was a problem using the hair for the other models, on Vicki or Mike. I use other hair on Mike all the time, it just has to be moved around and positioned properly. My favorite (actually) is a prop figure called Women's Long Curls which I use for my Santiago character.
