Mon, Jan 27, 3:06 AM CST
Subject: Victoria 3 file placement
96romeo ( ) posted Wed, 23 June 2004 at 2:57 PM · edited Thu, 01 August 2024 at 11:23 AM
I have just gotten V3 and the morph pack. I have a problem with putting the body morph poses in the right palce. The INJ and REM and HIDE and UNHIDE. I don't know where to put any of it inside the Pose folder. The icons for the morphs show up in the poses palatte, but when I click on them, a put up window shows up and I have to go searching through the pose files to find the INJ and UNHIDES. I am a novice when dealing with Poser. Could some please help.
DCArt ( ) posted Wed, 23 June 2004 at 4:55 PM
The DAZ installer program should put the files in the correct place ... did you move them by any chance?
Francemi ( ) posted Wed, 23 June 2004 at 5:08 PM
When it comes to morphs, it's better to follow the Daz installer program instructions. But from what you said, I guess you installed them manually.
Study the image I made for you and you'll figure out where to put what ;o)
If you put them anywhere else or name the folders any other name, it won't work or you will have to edit each pose file manually and there are LOTS of them!
France
France, Proud Owner of
KCTC Freebies
Lord_Lucan ( ) posted Wed, 23 June 2004 at 6:40 PM
I've changed the location of the INJ/REM pose files for V3(put each parts INJ & REM pose file in one file instead of one for the INJs and one for the REMs) and they seem to work fine! I thought you just had to keep the folder containing the Deltas where it is! Aren't all pose files like that? they contain instructions, and paths TO the data (textures, deltas, etc). Maybe I'm wrong and in for a nasty surprise next time I use V3! lol!
Francemi ( ) posted Thu, 24 June 2004 at 12:01 AM
I've found a few (not too many but some) pose file (INJ/REM) that refer to other pose files and if those other files were not where they were supposed to be... you know the rest! So for the moment, I decided to let them be where they want to be. When and if I have a long period of free time, I'll edit all the files in arachnophilia and replace the reference in them so I can put the folders where I want them to be. France
KCTC Freebies
Bobbie_Boucher ( ) posted Thu, 24 June 2004 at 9:28 AM · edited Thu, 24 June 2004 at 9:29 AM
You could use CorrectReference Pro (CRPro) to fix any messed-up references. If the characters are created with Injection Pose Builder, they refer to the files in the !DAZ folders, and not the Pose files. Those should be ok. If the characters are created with another program, or manually, they likely refer to the Pose files, and need to be fixed. You can tell by opening one of the pz2 files in a text editor.
Message edited on: 06/24/2004 09:29
