Wed, Feb 26, 11:09 AM CST
Subject: Free stuff entry
ibassplayer205 ( ) posted Fri, 25 June 2004 at 8:20 PM · edited Wed, 26 February 2025 at 11:00 AM
Hey guys, noticed that my Ibanez GSR 205 has been recently put up in the free stuff section, and quite a bit of people have downloaded it. For those of you who did download it, I was wondering what you all thought of it?
Kemal ( ) posted Sat, 26 June 2004 at 12:16 AM
Is that the one which used to be in Cinema 4D format before ( in C4D free stuff section ) ???
If that is the case, that was a very good model, if not, I'm gonna download yours and let you know laterz !!! :)
Kemal ( ) posted Sat, 26 June 2004 at 12:50 AM
Well, that was not the one ! :)
Here we go, as you can see, if smoothing option is applied on the guitar body, it becomes bumpy, which basicly means that you need a little bit more defined surface (more poligons, expecialy at beveled edges), rest of it did not have the same problem (I did try to smooth it at 6 different angles)...
I would add that Poser users could have less problems, cuz i think someone said that poser rendering engine is doing poligon sub-division internaly, unlike Bryce ( i might be wrong about this, but models I make always look little bit beter in poser if they are on a low polygon scale ). Overall, good job on it !!! :)
P.S. Maybe, you should model those frets on the neck too, they look much better as a 3d objects then texture !!!
pakled ( ) posted Sat, 26 June 2004 at 10:53 AM
I've got it..I'll get around to using it..;)
xantor ( ) posted Sun, 27 June 2004 at 8:28 AM
Free stuff like this doesn`t have to be called bryce only, it is a wavefront object and can be used in almost any 3d program, poser 5 users could use this as bryce materials can mostly be duplicated in the poser 5 material room. If it was in the freestuff as a wavefront object then more people would download it and use it, you could say in the notes that it was specifically made for bryce but will work with other programs with some work.
