Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 6:55 am)
Hi You need to add additional keyframes between the start of the animation to the point where the character starts whatever action you want. The easiest way is to copy frame 1 of your animation and paste it into your animation before your character starts the desired action. You will probably need to change the interpolation of those frames too. Hope this helps Ed
had a quick question about keyframing/animating in poser when dealing with 2 charecters, or just a string of movements. How do I make it so that when a charecter does a movement, such as a wave, and then say a head turn. That these movements appear to happen one after the other. Ive noticed that say i animated this in Poser, while the charecter waved his head would slowly be turning until it reached its final position on a later key frame. Ive also run in to troubles when trying to animate fight scenes. When a charecter dodges another persons kick he starts the dodge as the other charecter starts the kick etc. How do I un merge these actions so they happen in a sequence, rather then being molded together.
