Thu, Jan 9, 5:03 PM CST
Subject: Order of installation on Poser 4 and Pro Pack...
Techyman ( ) posted Tue, 29 June 2004 at 9:59 PM ยท edited Thu, 09 January 2025 at 8:02 AM
It's been a long time since I've had a chance to use my copy of Poser 4 and the Pro Pack (both purchased from Curious Labs) and I've downloaded the latest patches for them. I have a new system and I'm looking forward to getting back into Poser after a year and a half absence. My problem is that I seem to remember having a problem when I installed them on my old system and ended up having to delete and reinstall everying two or three times in a different order so that everything would work properly. Is there a particular order for the installation? I know P4 comes first, but before I spend two or three hours on this project, I thought I would get some advice from the experts. Thanks in advance for the help!
atilla39 ( ) posted Tue, 29 June 2004 at 11:05 PM
Well I installed Poser 4.....then the updates....memory update and then Pro Pack...Worked fine for me.
movida ( ) posted Wed, 30 June 2004 at 12:17 AM
I had a problem once after installing Pro Pack - it wouldn't open and gave me an error that some file or other was missing. I copied the file name, did a google search for it, downloaded it and backed it up. It never happened again.
SWAMP ( ) posted Wed, 30 June 2004 at 1:14 AM
Here is the order.... 1)Poser4 2)ProPack 3)ProPack update This is where problems happen.. When you run this update,it points to your installation... click no,and browse to Poser yourself (it will be the same loacation,but that is a bug in the installer). 4)Memory update (FOR PROPACK). Note:You do not need to installe the update for plain Poser4. SWAMP
