Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 24 1:37 pm)
Wow that is starting to look great. Way better than anything I have been able to do as far as making a recognizable character. If it helps, I noticed that when the image was loade, and just the upper half of his face was showing, top of hat to just above tip of nose, there was no recognition on my part. However, when the remaining half loaded, I clearly saw HF. I checked this, by scrolling up and down, and noted again, that when I few just the top half, I do not see a resemblence but with the lower half alone I do.
Thanks for all the comments! Let me see if I can answer in order...
TygerCub: You're definitely right about the texture. I've got a very high res texture for the face, but it needs cleaning up. The body tex is based on Kane, but the Kane tex (believe it or not!) is not hi res enough for what I'm trying to accomplish here (either that, or I'm just not using it right). I'll probably bite the bullet and work on an all-new body tex at something like 4000X4000 (or higher?!?!?) soon. That's going to keep me busy for a while! :-)
Shadownet: Hmmmm, you're right. I think it's mostly the eye shape - I've been tweaking it for ages, and it's hard to get just the right HF squint (it's almost as distinctive as Clint Eastwood's). The HF factor is more noticeable with the hat off, as I've duplicated his forehead lines, but I definitely need to keep working on those eyes...maybe some work on the temples too (no pun intended!)
Kristta: re Han Solo - sure, why not? :-)
Jaybutton: yeah, that's the one thing I still haven't figured out on Black Eyes/Actual Eyes. I had veins in his eye whites, but then they disappeared! I wonder how that happened...any suggestions, anybody?
Casette: No, no, no - Alan Alda! :-D
-Mike
Hi, artnik. Thanks for the tip. You're quite right about the nose, of course. I have managed to get the tip of his nose to slant (maybe that's part of why the resemblance is better from the tip of the nose down), but I've been having trouble getting the rest of the nose to follow suit. Any suggestions about which dials to use to "break" the nose correctly? -Mike
Thanks for the kind words, Kristta. Han and Leia with kids - sounds like it could be a very interesting image :-)
At TygerCub's suggestion, I went back and looked at the image size for the head tex. It's only 1500X1500. I decided to go for broke - I'm now working on a 4000X4000 head tex! It's going to take a while - stay tuned for updates! :-D -Mike
Hello. As some of you may have seen in my recent post, I tried redoing Indy a little while ago. On further reflection, I think I've realized that I was almost completely on the wrong track!I went back to the original Indy head shape (no more Baretta, I hope! ;-) ), changing only the nose and a few other minor things. I kept the "new" fedora from the first "Redux" version. I went back to the original light setup. I changed the camera angle to be slightly more "dramatic." And - finally! - I really did get Black Eyes working (I was wrong about it working before).
I still need to do a fair amount of work, especially on texture seams, etc. But this is much closer to what I originally had in mind...TIA for any and all comments or suggestions! -Mike
