Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 6:38 am)
Not much help I know, but you're not alone in being unable to change texture maps in P5. I love the P5 procedurals and don't have any problems with them. I'm totally incapable of changing texture maps though, except by individually selecting and applying to every body part seperately, which is pretty slow and tedious :(
John
Essie - are you trying to apply the texture to the "Preview"? That won't work. What John said might be the (tedious) answer: the (relevant) textures might need to be applied separately to the (corresponding) parts. 1 by 1. If that is the case, I suggest you take a few minutes to (sigh) apply the texture to all the bits. Then render to ensure you didn't miss something. Then save the figure/prop/whatever into the relvant library (as xyzRetextured, or similar). Or, if the figure/prop/object in question has several/many groups, but are all textured via the same single texture-map, then apply the texture to just the 1st real (not Preview) group; rt-click in a blank bit of the Mat-room and select "Apply to all" (I think that's what it's named) Sorry if that sounds a bit garbled, I'm over my alcohol limit (but I hope it helps..) Cheers, (HIC!) Diolma
Attached Link: http://www.sams3d.com/HotAirBalloonTemplate.htm
Actually here it is now....they normally come with the download in the zipped file anyway. You should have them already, but just in case you can't find them, download it from here. SharenThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I've tried this twice now, and once i go into P5 to apply the texture it reneders with the texture that Sams has on it orginally. Can this not be done with Sams3D freebies? thanks ---Essie
