Mon, Feb 24, 6:44 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 24 1:37 pm)
Subject: Vicky 3
Wizzie ( ) posted Sun, 11 July 2004 at 11:26 AM ยท edited Mon, 24 February 2025 at 6:30 PM
Attached Link: http://homepage.eircom.net/~twg2002
I was trying to re create the 6" Heels for P4 to Victoria, wenr well but then realized that there is a problem with Vicky3 ankles, they seems to be not inlinte with the shin. Is it just me or anyone else have the same problem?? If yes, any fix for that???
PhilC ( ) posted Sun, 11 July 2004 at 11:41 AM
Are the IK chains turned off? Could you post a screen shot? Not sure I quite understand. Thanks
Wizzie ( ) posted Sun, 11 July 2004 at 12:07 PM
Didnt check that, i will after pub time;-) here is a pic
nakamuram ( ) posted Sun, 11 July 2004 at 5:03 PM
Ziggie has a cast and crutch set available. That might help. I do not have that problem. Select V3's Body, turn off IK, open the joint editor, then press Zero Figure.
lhiannan ( ) posted Sun, 11 July 2004 at 10:08 PM
Do you have P4, Poser Pro Pack or P5? If it is Poser 4, you may have a corrupt rsr. Go into your Geometries folder and delete the rsr file that accompanies the V3 obj file (NOTE: The RSR in the GEOMETRIES folder in ZygotePeople or wherever your V3 obj installed and NO where else. Deleting corrupt geometry rsr's is routine maintenance in P4)
Wizzie ( ) posted Mon, 12 July 2004 at 4:08 AM
Cheers il trz that tonite
