Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 1:40 am)
I'd start by adjusting the brightness/contrast levels of the figure to see if the lighting matches up with the background, which I don't think it's going to, but it's hard to tell since everything is a little muted on the figure. The first thing I see is that the extremely bright light in the background should be illuminating the figure more from that side, and shadows from such a light source would likely be a bit sharper, like those produced from sunlight. Also, as previously mentioned, the face should be catching more light from the "magic" beams. (This is where point lights in Poser would come in extremely handy). Perhaps try those particular adjustments, with an emphasis on placing lights in the scene corresponding to those in the background, and you'll probably have a much easier piece to work out in post. :-)
Tools : 3dsmax 2015, Daz Studio 4.6, PoserPro 2012, Blender
v2.74
System: Pentium QuadCore i7, under Win 8, GeForce GTX 780 / 2GB
GPU.
There is no light in the background.
This whole scene only had 3 lights in it: one between her hands, one below and to the right in the image, and one above and to the right (sorta pointing at her hat).
The background is an effect figure. The atmospherics brought that particular brightness out.
I'm actually thinking of re-rendering the scene now, except without any lights.
I actually sorta liked it -- I'm a bit of a nut about magic, which I've never seen as being something that "cast" light so much as was simply made of it (more plamsa than gaseous).
Ok...
hmmmmm
I will look at perhaps adding a fourth light in, or at east adjusting the shaders on her eyes...
Thank you all, so far, though! More, more!
Message edited on: 07/11/2004 22:05
These show the lighting better, I think. Looking at them, perhaps a fourth light following the angle of her body up to her face would work? (sorry about the image -- it's the only one I had handy, and the scene takes about 15 minutes to render without light effects, 4 hours with)
Message edited on: 07/11/2004 22:18
ok, I've got the poem figured out for it, at least, lol. I'm going to fiddle wiiht some lighting tweaks and change the background slightly, and post the new version tomorrow.
