Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 6:38 am)
I always just delete the geom lines and then paste in the code 'cause every single time I try something else, I get something that doesn't work. lol Be sure the brackets are in the right places, and that there is no custome geom anywhere in the new prop is the best I can say.
I've compared the code in mine to other .pp2's and it's identical apart from the obvious material settings etc. Still no joy shrugs @geogress.. I know about the folder i just put blah blah for example :) Is there a quicker way of deleting the custom geom than having to spend ages highlighting it all and deleting?
I'm carefully comparing a .pp2 with an external geometry call and a standard Poser-created .pp2 with included geometry, and I can't see any difference outside of the GeomCustom section on the one and the section containing the objFileGeom on the other. I suspect you have a missing bracket somewhere. Poser gets real cranky about those. Also...Poser dislikes body parts that start with capitals, or spaces in file names. Hmm. Does the external mesh have an internal name? It could be Poser is opening the file, all right, but not finding the "actor" it wants.
nomuse may have hit it one the head there -- object names gotta be exact, and never allow spaces in your file name on an external call. and by the way, anyone want to take up a collection for nomuse? Everyone should have at least one...
Ok got it working now :) I think it was the internal names where I was making the mistakes. I changed the name of the external object and re saved as a prop and then pasted the new code in. Works fine now, although I did have a litte problem with it changing all the scale settings grr Thanks for the help, I appreciate you answering a question that has probably countlessly been answered many times before :) Hands out virtual pints of beer
Here's another question: shouldn't the middle "0" (after "storageOffset") be "0.3487"? Isn't this the Y coordinate, which places the prop on the ground?
For example:
prop FuelProbe_1:1<br></br> {<br></br> storageOffset 0 0.3487 0<br></br> objFileGeom 0 0 :Runtime:Geometries:JHoagland:blackhawkfuelprobe.obj<br></br> }
--John
VanishingPoint... Advanced 3D Modeling Solutions
huggs to nomuse. John, I think you're right, near as I can tell. I'll have to look at my copy of the offset tables if I can find it (and if not, then it's back to tht nightmare search online for it once again...)
Attached Link: http://www.globetown.net/~kim99/tool/CR2Builder/02h/indexe.html
CR2Builder loads Poser files without actually loading the deltas or geomCustom into memory, so all you have to do is find the stub it loads and delete that. After following the link above, choose the link labeled 02h18.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I probably guess this has been answered many a time before, but i'm having some problems making some props i'm working on load via external geom. I've saved as a .pp2 and then took another .pp2 (deleted all the code in that one) and copy and pasted all the relevant code into the new one adding in the.. storageoffset 0 0 0 objFileGeom 0 0 :Runtime:Geometries:blahblahblah.obj I did this as it's usually quicker than manually having to delete all the nasty custom geom. But when I come to try it out it loads something.. it isn't visible (I can only see it in the hiearchy menu but not in the scene or in the menus) Just what have I done wrong? And how do I fix it? It's driving me mad now hehe
