Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 16 7:48 pm)
This sounds similar to the problem P5 has with Yann Hair by Neftis. It seems P5 doesn't particularly like very hi res transmaps on high poly objects, or something to that effect. I think Neftis posted a workaround at her Polymage site, which (IIRC) involves reducing the texture and transmaps to a lower res. Unfortunately, the site is inacessible (to me) at the moment, so I can't verify that.
Thanks yall think I got it figured out. It seems that you cannot load the beard as the 1st object in a scene it kills P5 every time. If I load up David or Freak and THEN the beard it works now. I never would of guessed it was a load order issue.Of course I didnt RTFM ...but found a resolution to the issue at the "Nuts and Bolts" forum at DAZ.
Hello , I was wondering if anyone has had problems with the new Daz Mil-Beards for Freak and David and Mike? When I try to load up the beard for D3/M3 or Freak it causes my P5 to crash to the desktop which has never ever happened before, and the mil beards are the only items to cause this. Anyone else have this happen to them or is it just me? Thank you in advance.
