Thu, Nov 14, 4:12 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 12:36 pm)
Subject: Problem with texture rendering in Poser 5
faveral ( ) posted Tue, 20 July 2004 at 5:36 PM · edited Thu, 14 November 2024 at 4:05 PM
Hi all, I have a custommer who experiences a problem rendering one of my models with Poser5. As you can see on the picture some polygons appear to get a brownish color on their own, which doesn't happen in PP or P4. Does any one have a clue what is happening and how to fix it ? Thanks in advance !
Veritas777 ( ) posted Tue, 20 July 2004 at 5:51 PM
BTW, Thanks Faveral for another incredibly detailed and excellent model. They are among the very best models I have ever owned and work really well in other 3D apps. Hope you find the P5 problem. I still use P4PP for nearly all my Poser render needs.
Silke ( ) posted Tue, 20 July 2004 at 6:08 PM
Faveral, do you have smooth polyglons on? I get that sometimes when I have it on in P5 on some models. You may want to turn it off on areas where you get the brown stuff. (you can turn it off individually on a bit in the parameter dials for that area) Also, try using a very small (0.001) setting on displacement. That sometimes helps. Hope this is of any use to you. If it doesn't work, try stopping over to runtimedna.com and posting it in their P5 section. There are some of the most excellent users in that forum, I'm sure someone will be able to help if you don't get any joy here :)
Silke
iloco ( ) posted Tue, 20 July 2004 at 6:33 PM
Hi Silke I am having the problem with Poser 5 and the brown in the canvas. I can load it in poser 4 and all is ok the same as faveral has shown in the pictures. I did try what you have suggested and still getting the brown in the canvas texture. I am fairly new with Poser 5 so it takes me a while to get it all figured out.
ïÏøçö
Valandar ( ) posted Tue, 20 July 2004 at 8:04 PM
Sounds like the ol' Double-sided polygons issue...
Remember, kids! Napalm is Nature's Toothpaste!
nickedshield ( ) posted Tue, 20 July 2004 at 8:08 PM
faveral, take a look at the render: I connected the texture to the Displacement node and set it at 0.06. Renders fine in Firefly, default. BTW single side smoothing was on in this render.
iloco ( ) posted Tue, 20 July 2004 at 8:26 PM
It worked perfectly for me with your instructions. Thanks.
ïÏøçö
nickedshield ( ) posted Tue, 20 July 2004 at 8:31 PM
You're welcome :)
faveral ( ) posted Tue, 20 July 2004 at 9:35 PM
Thank you all, Veritas, Silke, Valandar and nickedshield. You guys rock ! I'll make sure I stay away from double sided polygons in the future ! Thanks again ! Luc
