Sat, Sep 21, 9:27 PM CDT
Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
Subject: Underwater scenes
TRIPD ( ) posted Sun, 25 July 2004 at 4:23 PM ยท edited Sat, 21 September 2024 at 9:26 PM
I am trying to develop underwater scenes. But I am having trouble actually getting it to look like it is underwater. I have left a picture that I have done so far if anyone could help me with either a tut for this or ideas on how to make it look more like it is underwater I would appreciate it thanks.
Stephen Ray ( ) posted Sun, 25 July 2004 at 5:16 PM
First I would change the sky ( get rid of those clouds ) try using one of the preset skies like Caribbean Clear or Peach Haze. They have no clouds and the color and haze can be adjusted to create an under water atmosphere. Also think a real world situation. If your doing an underwater scene, put it underwater.
Stephen Ray
TRIPD ( ) posted Sun, 25 July 2004 at 9:53 PM
this is my 3rd attempt at an underwater scene I think i got a wee bit closer
AgentSmith ( ) posted Sun, 25 July 2004 at 10:12 PM
Oh, yes you are. The hardest part, imo, is the "sky" settings. To make it look more like murky water. And, yeah, like Stephen said, you can later put your scene underwater. I myself just tiled a set of terrains that looked like ocean waves (I like "slickrock"), and positioned it above my scene. If you ever do that, don't make them "solid", it can turn out looking strange. (in my scene it did, anyway) AS
MuddyGrub ( ) posted Sun, 25 July 2004 at 11:11 PM
I prefer to use two different renders for underwater scenes. One for the entire scene, and the second for the underwater murky sorta feel. That's the approach I used for the underwater scene in my gallery. Yours is coming along great. Good luck!
blaufeld ( ) posted Sun, 25 July 2004 at 11:15 PM
Take a look at this!!! http://visualmagic.awn.com/archive/archive06.html :)
SAMS3D ( ) posted Mon, 26 July 2004 at 4:34 AM
These are fantastic. Sharen
Batsarse ( ) posted Mon, 26 July 2004 at 10:40 AM
You could try using a volumetric slab - I don't tend to use them much myself, because they can push the render time right through the roof, but if you Alt-click (or it might be Ctrl-click - it's one of them!) the water terrain button at the top left of the Bryce toolbar it will create a "block" of water rather than a 2D plane. You can apply a suitable water texture to this "block", which can then be stretched up out of the field of view. Then you can play around with the light settings for that lagoon or abyssal depths look. Word of warning about volumetric renders, though: I'm not kidding about the render times - they can be enormous, so if you're looking for a quick fix to your problem this may not be it. That's why I tend to avoid them (I have no patience!) IIRC, there's one volumetric-slab render in my gallery titled "Pollution". It's nothing special but it should give you a basic idea of the potential of the voluemtric slab. Hope this helps.
TRIPD ( ) posted Mon, 26 July 2004 at 1:57 PM
I used a slight compilation of the suggestions here to get this I do believe I am alot closer to achieveing what I want. Thanks for all the halp so far and any suggestions on how to make the scene better is appreciated.
Dennisld ( ) posted Wed, 28 July 2004 at 10:16 AM
Attached Link: http://www.3dart4u.com/1024/index.htm
If you'd like to experiment with some underwater mats and skies you could do worse than Menno's Underwater package. It's at the link, click on the whale image.
January's Challenge at this site was 'Underwater Realism with Bryce' with some 70 odd entries won by Agent Smith.
Well worth a look through for some of the best underwater images posted at Renderosity.
Realistic underwater images are recognosed as the most difficult to master with Bryce so good luck with your efforts, your coming along nicely.
Bye now...........Dennis
