Sun, Sep 22, 8:29 AM CDT
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Sep 17 7:30 pm)
Subject: Windows 2000 crisis
denden ( ) posted Sun, 29 October 2000 at 3:05 PM · edited Sun, 22 September 2024 at 8:13 AM
Poser 4 won't run on my Win2K box. "not enough memory". It's a 933Plll with a gig of RAM and three 36 GIG drive Raid Array. Painter6 also will not run. Both proggies run fine on a WinNT box. Will appreciate all suggestions. Dennis
Kavakus ( ) posted Tue, 31 October 2000 at 7:18 PM
Attached Link: http://www.curiouslabs.com/downloads/html/Poser4Updater.html
I had the same problem... It's because the programmer was probably an IBM programer and as such put a max cap on the RAM... This Patch fixes the problem... Enjoy and hope to see some of your work on the web LouHawk
denden ( ) posted Wed, 01 November 2000 at 9:47 AM
Thanks zillions LouHawk...the patch from Curiouslabs did the trick. Not only that, I also patched Painter6 and now it runs fine on Win2K. What a relief! Dennis PS this is a great forum.
