Sun, Nov 10, 3:59 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 09 11:21 pm)
Subject: I changed my Pose dir around and now INJ/REM broke...Utility?
Photopium ( ) posted Sun, 01 August 2004 at 5:46 PM ยท edited Wed, 06 November 2024 at 6:49 AM
Does anyone recall a utility to make inj/rem work even if you've changed the directories around? Thanks -WTB
SamTherapy ( ) posted Sun, 01 August 2004 at 6:13 PM
Don't recall seeing anything to help. AFAIK, you have to put your INJ/REM poses in the main Pose directory. I tried moving them, which didn't work at all, so I just copied 'em back.
Photopium ( ) posted Sun, 01 August 2004 at 6:18 PM
Well, I fixed the reference directly in the "all remove" files. However, I'm still having a problem getting Poser 5 to hide the friggin morphs :S (grr) -WTB
Ajax ( ) posted Sun, 01 August 2004 at 7:17 PM
Bobbie_Boucher ( ) posted Sun, 01 August 2004 at 11:18 PM
Yes, Correct Reference Pro (CRPro) will do the job nicely. One thing to bear in mind is that some artists/utilities refer to the files in the !DAZ library files, while others refer to the Pose files that refer back to the !DAZ files. That can get tricky.
gstorme ( ) posted Mon, 02 August 2004 at 1:34 AM
Just do not move the :Runtime:Libraries:!DAZ directory. Other files reference this directory.
You can move the other directories to anywhere under :Runtime:Libraries:Pose e.g. group all David INJ/REM dirs in one :Runtime:Libraries:Pose:!David dir
When done so, you do not need to edit files :)
Kalypso ( ) posted Mon, 02 August 2004 at 1:51 AM
Site Admin Online Now!
gstorme is right. I've got my David and Stephanie INJ and REM directories in the face library and Mike and Vicki in the Pose - otherwise I'd have to move a lot of pose files around. As long as the files these poses reference are not moved you're ok.
cuba ( ) posted Mon, 02 August 2004 at 8:03 AM
Attached Link: http://www.boolean.ca/replace/
Like Bobbie_Boucher said, the problem occurs when the INJ/REM files refer to other pose files rather than referring to the !DAZ directory. I use a free program called "ReplaceEm" to fix the references. With it you can replace text in multiple files. Very powerful and easy to use.
