You can also create your own catagory on this drop down... Go into you BBRYCE folder. Look for 'PRESETS' Go to 'OBJECTS' Copy, paste elswhere, rename, Tutorial file (see post #2 above) rename to something like 'MY OBJECTS' Cut & Paste back to the PRESETS folder. Load up Bryce. Open your new 'MY OBJECTS' and delete eveything. IMPORT your own objects. VIOLA!
Ang: I didn't know you could do that?
that's how i do it is by adding new folders. I have a folder for installed, for downloaded, and for my own creations. It allows you to keep more stuff in a more organized and easy to find manner. Somewhere, cant remember where, there is a tut on how to do it for the materials library but the method works the same for the objects library as well. It might be brycetech 101 but not sure
Message edited on: 08/03/2004 12:29
I knew there was something about this I'd forgotten. Ang IS right of course, but so is Yewston! Except that although there is ot limit to the number of .mats you can store in one folder, Bryce gets a bit ornery and tends to complain when you add too many. This can lead to crashes...... I think a better arrangement might be to create you own catalogue BUT save it out to somewhere safe and only load the individual folders of .mats when you need them. eg: If you are going to create an industrial scene you might have all your metals and technical .mats in one folder ready to 'install' into Bryce with just a few clicks. I've been thinking about doing this with bricks and stones which I find very handy.......
Bea: I don't think that's right.
Bryster, I think Bea is sort of right, depends on what you delete, sometimes the pic disappears but the stuff is still taking up space in a folder, thus causing that nasty overload issue mentioned above. I tend to leave everything I put in, in, that way I know how much is really in there. But then again I could be wrong too.
Ang: You can check this by creating a copy of a folder and deleting the contents, then compare the folder sizes....
