Attached Link: http://www.renderosity.com/messages.ez?ForumID=106
It would be difficult to use the plugin because of the separate maps. The plugin was designed for Poser3. You could possibly import the OBJ file and apply the maps through the shader editor. Try asking this question over at the Carrara/RDS forum section: http://www.renderosity.com/messages.ez?ForumID=106 -JH.P4 figures do not texture properly in RDS 5.5. You get white seams at the edges of the texture. I don't think anyone has found a remedy for this. I strongly suspect that Vicki and Michael will have the same problem, although I have not tested it (can't hndle the frustration).
Hi, Can Michael be exported from Poser4 and rendered in Ray Dream with all the textures? How can I do this?
