Sat, Jan 25, 3:18 AM CST
Subject: Q regarding GIRL texture...
Djeser ( ) posted Sun, 08 August 2004 at 7:38 AM ยท edited Fri, 10 January 2025 at 4:42 AM
I applied a body/head texture (one of the GIRL texture packs) via MAT pose to the GIRL and got a mysterious hodgepodge...lips on forehead, like the whole map was sideways and sized strange. Does that mean the map is for the V3-UV mapped GIRL cr2? (Can't check right now, in midst of very long render on that machine, lol) TIA
Sgiathalaich
shazz501 ( ) posted Sun, 08 August 2004 at 7:44 AM
was it the figurine texture?? i believe that is for the V3-UV version as it says in the ad at daz that it can be used on V3 also :D i hope this helps
DominiqueB ( ) posted Sun, 08 August 2004 at 8:33 AM
There are two Girl cr2's: one called The Girl, this is the one that takes the textures supplied in the Daz's texture pack, the other one is called The Girl V3_UV this one takes all of V3's textures, the only thing that you have to watch out for is that since she has modelled lashes the lash transmap do not work.
Dominique Digital Cats Media
Djeser ( ) posted Sun, 08 August 2004 at 8:53 AM
Thanks to both of you...I finally finished my render and found that! I was also testing a V3 texture on her and looks like there are no eyelashes, so will have to figure that out. should I just make sure there's no lash trans for the lashes in the materials?
Sgiathalaich
DominiqueB ( ) posted Sun, 08 August 2004 at 9:19 AM
Make sure that the transparency is set min and max 0%, and no transparency mat for the lashes.
Djeser ( ) posted Sun, 08 August 2004 at 9:22 AM
Great! Thanks very much, DominiqueB, I appreciate you taking the time to help me! Have a great Sunday!
Sgiathalaich
