Sun, Jan 26, 11:29 PM CST
Subject: OBP Preview Size, how to adjust?
electroglyph ( ) posted Fri, 13 August 2004 at 2:50 PM · edited Sun, 26 January 2025 at 11:28 PM
Objects that I create and attempt to import into the bryce presets library sometimes have little bitty preview images. The only way I have found to fix this is play around with the object scaling. Is there a zoom control in the preview pane so I can make created objects fill most of the preview box?
ranachronos ( ) posted Fri, 13 August 2004 at 3:14 PM
Hold down CTRL key, click + hold left mouse button on preview, then move mouse up + down to zoom in and out. Likewise, hold down SHIFT to rotate, or SPACE to scroll up + down. (Pretty sure those are right .... at work so I can't double-check)
Angela252 ( ) posted Fri, 13 August 2004 at 6:23 PM
I always get the darn roots of a tree when I add it to my library. I will have to try these ctrl keys! Thanks!
TheBryster ( ) posted Fri, 13 August 2004 at 6:34 PM
Rana is right!
ysvry ( ) posted Fri, 13 August 2004 at 7:11 PM
great tip i always got tiny previeuws too lol
for some free stuff i made
and for almost daily fotos
dan whiteside ( ) posted Fri, 13 August 2004 at 7:12 PM
You can also use the "Close Up" option on the popup below the preview. HTH; Dan
