Thu, Jan 30, 5:38 PM CST
Subject: Printing Images
susanmoses ( ) posted Wed, 18 August 2004 at 2:16 PM ยท edited Thu, 30 January 2025 at 5:30 PM
Hey Forum Guys:
I am about to print some architectural images to be mounted on regular 1/8" 'Mat Board'... then recessed slightly into a 24x36 Polycarb (1/4" thick corrugated plastic mat.) Board. Since I have never printed artwork before... I was wondering if anyone here could take me through the process. I imagine you save it to a CD and then find a good Print Shop... but there are probably some tricks, tips and pitfalls to be aware of... Thoughts and responses much appreciated. -Susan
Message edited on: 08/18/2004 14:17
Stephen Ray ( ) posted Wed, 18 August 2004 at 5:12 PM
The printers I have worked with wanted uncompressed formats ( EPS ) is what I used, that format supports Vector and Raster type graphics. In Bryce large images need to be Rendered to Disk with DPI resolution of 300 ( print res ) Be aware that there is a sight color shift between RGB ( computer monitor color scheme ) and CMY ( color scheme professional printers use ).
Stephen Ray
susanmoses ( ) posted Wed, 18 August 2004 at 6:14 PM
Thank you Stephen... is there an option for an EPS format in Photoshop, as well as an option for DPI 300? -Susan
Stephen Ray ( ) posted Wed, 18 August 2004 at 8:02 PM
You can not change a 72 DPI image to 300 DPI without the dimensions of the image shrinking drastically. The image needs to be rendered out at a massive resolution set to 300 DPI That's one of the reasons Bryce has a render to disk option Here's a quick run down on how to set up and rendering to disk ( in Bryce ) First you need to set the document aspect ratio, the dimensions you stated are 24X36 In. The document does not need to be as big but the aspect ratio needs to conform to the same dimensions. So go to File/Document Set-up, On the Document Set-up Menu type in a value of 2 : 3 in the Document Aspect Ratio fields, then type in 400X600 in the Document Resolution fields. This should give you a document with the correct ratio and a manageable mostly viewable work space. Do a fast test render to see if the scene fits in these dimensions. ( set to no AA if need be to speed the render up ) Correct any camera setting to fit the scene if need be. Set the render options to what you want AA, premium or what not. The Render to Disk option is located on the File Menu / Render Tab. When the menu opens first type in 300 in the DPI option Then type in the dimensions in the inch options 24X36 ( bottom fields ). Exit the menu by hitting the check. In the Save dialog, locate a place to save, name and set the file type to one with no compression ( BMP or Tiff ). Hit OK and the render starts. If you stop the render an option will appear to resume or cancel the render. ( this type of rendering can not be stop, then restarted at a latter time or day ) Be prepared for a render of this size to take awhile ( possible even days ). Talk to the printer people ( or who ever is publishing the piece and ask them what file type they prefer. You may not need to convert the image to EPS in Photoshop. But if you do simple open the image in Photoshop and use the Save a Copy option and set it to EPS.
Stephen Ray
pogmahone ( ) posted Wed, 18 August 2004 at 11:41 PM
This is all WAY over my head.......but one thing to be aware of is that your monitor may show colours up very differently to how they come out in print. I recently got a series of Bryce images printed out for a presentation, and they came out very very purple compared to how they looked on my screen :o( So it could be worth having a test run at a smaller size to see how colours are printing off.
susanmoses ( ) posted Thu, 19 August 2004 at 12:12 AM
Thanks pogmahone... you probably just saved me a lot of dissapointment... I just knew there were pitfalls in this... seems to be one of those general themes in life and after a while (and lot's of experience) you 'look' or 'ask' before you leap. -Thanks again, Susan
airlynx ( ) posted Thu, 19 August 2004 at 9:04 AM
I never thought about using EPS. I've used PDF for all my school projects up till now, taking them to Kinko's as needed (low file size and good quality there). 300 DPI is an industry standard and usually looks the best. Colors are a pain in the ass, and if possible convert to CMYK in Photoshop. CMYK is the colors printers use, Cyan Magenta Yellow and Black. (who the hell represented black with a 'k'?)
